Give me a shout when they turn up Lawrie, I could pop over and give you a hand/watch and laugh... nothing better to do in Greenock! What version of VCDS you using? I think you'll need the 11.11.04 software for it?
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
I bought myself a genuine cable and I'm running 11.11.4 nowwould be good to have someone that knows their way round vgom helping though lol!
The guys in holland posted this :
It is possible to disable the can-bus check
Select 09 (Central Electronics)
Long Coding -> Function 07
Byte 02 Bit 2 Cold Lamp Diagnosis active
Byte 18 Bit 0 Cold Diagnosis License Plate Lights active
Byte 18 Bit 1 Cold Diagnosis Brake Lights active
Byte 18 Bit 2 Cold Diagnosis Front Fog Lights active
Byte 18 Bit 3 Cold Diagnosis Rear Fog Lights active
Byte 18 Bit 4 Cold Diagnosis High Beam active
Byte 18 Bit 5 Cold Diagnosis Turn Signals active
Byte 18 Bit 6 Cold Diagnosis Back Light active
Byte 18 Bit 7 Cold Diagnosis Side Turn Signals active
Byte 19 Bit 0 Cold Diagnosis Low Beam active
Byte 19 Bit 1 Cold Diagnosis Front Parking Lights active
Byte 19 Bit 2 Cold Diagnosis Rear Parking Lights active
Byte 19 Bit 3 Diagnosis Rear Parking Lights active
so no need for can bus LED, etc
I also have a 29 page pdf document showing the ibiza 6J VCDS options.
PM me your e-mail if you want a copy.
Oh and I would greatly appreciate if you could plug your 11.11.4 into my car to disable the high beam cold bulb warning... won't let me on 10.6![]()
we need to find out which vehicles can have this led function enabled and which cant really. duno about others but i dont fancy having a bulb warning light on
Not a problem mate, I'm bringing the laptop with me on Saturday so we'll get you plugged in then )
