Hi there guys. I a newbie in this forum and before reading this post I have tried many things read in other forums. By the way there is no way to remove the warning light.
I have tried disabling the fused light check (all of them) but or is not working or I did it wrong.
Can you
help me please?
I drive a
Seat Ibiza 6J (mk5) FR TDI bought in 2011.
Thanks in advance
What software and cable are you using ? - many of the cheaper cables with copy software will not work on the MK5 correctly.
It is possible to disable the can-bus check ( light check )
Select 09 (Central Electronics)
Long
Coding -> Function 07
Byte 02 Bit 2 Cold Lamp Diagnosis active
Byte 18 Bit 0 Cold Diagnosis License Plate Lights active
Byte 18 Bit 1 Cold Diagnosis Brake Lights active
Byte 18 Bit 2 Cold Diagnosis Front Fog Lights active
Byte 18 Bit 3 Cold Diagnosis Rear Fog Lights active
Byte 18 Bit 4 Cold Diagnosis High Beam active
Byte 18 Bit 5 Cold Diagnosis Turn Signals active
Byte 18 Bit 6 Cold Diagnosis Back Light active
Byte 18 Bit 7 Cold Diagnosis Side Turn Signals active
Byte 19 Bit 0 Cold Diagnosis Low Beam active
Byte 19 Bit 1 Cold Diagnosis Front Parking Lights active
Byte 19 Bit 2 Cold Diagnosis Rear Parking Lights active
Byte 19 Bit 3 Diagnosis Rear Parking Lights active
so no need for can bus LED, etc
