Fitting fog lights.....where to start?
abhardwaj1990
Yes, I'm licking my hand
Mar 16, 2009
3,434
Shottingham
Some of you may know I've recently facelifted my beast, I got some fogs with the bumpers and also the fog switch.
My car was the CLS model which never had fogs..........So is it possible to wire the fogs up?
Cheers :)
Caffienated
224
Bristol
Not sure if the wiring's in the harness as standard, but even if it isn't, it shouldn't be too hard.
Basically, you want am auxilliary lighting relay, using the fog switch pull as your trigger, and probably chop the dip beam wire to provide your +ve rail. There must be a million wiring schematics for fog and driving light wiring lurking a google away... Probably a good plan to put an in-line fuse in circuit too, so that if anything does go sparky you don't lose your dip beam fuse too...
abhardwaj1990
Mar 16, 2009
3,434
Shottingham
Thanks for the response, going to have a search for the diagrams now.
Times like these I wish I still remembered everything from electronics at GCSE lol
