Fitting Temperature sender
webcomsystems
87
About to fit a new temperature sender unit tomorrow.
Had a look at the old one and it only seems to be held on with a plastic circlip type thing???
I waggled it around and coolant started coming out!
Does anyone else think this is a shite way to attach a component which is operating under heat/pressure?????
LouisAUQ
75
http://www.seatcupra.net/forums/showthread.php?t=406919&page=2
Check my last post. Make sure the engine completely cold otherwise the coolant will be under pressure and will leak like a *******. Otherwise its easy peasy, pull C clip out, pull sender out of hosing, remove sensor from loom, fit new sensor to loom and back into the hosing with new o ring, make sure the sensor is properly fitted before putting the C clip back on.
webcomsystems
87
Thanks for that!
I get the same with my 1.9tdi in that my Temperature gauge(and ODB II) show about 75 degrees once warmed up.
I get serious power loss when trying to accelerate once warm, but less so when cold.
If I need to replace my thermostat, where is this located?
LouisAUQ
75
I have no idea on the diesel. 1.8T it's beneath the inlet manifold
