Ryan Schofield
Hello, I have a 2010 Ibiza Cupra and I have decided to fit some LED indicator lamps. This has made the inside indicator signals flash like crazy but the outside ones are working fine. I think I can just change the indicator relay for an LED friendly one and this should solve the problem without having to wire in individual resistors at each lamp. Does anyone know where I can locate the indicator relay?
I think that you will find that this function is taken care of by the BCM and not by a small cheaper part like a flasher unit, so unless the BCM can be recoded to accept LED bulbs, then you will need to find CAN BUS compliant LED flasher bulbs.
