Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
Timpsons will do it for about £10 but they will give you the warning before hand that they are not held responsible if they break the blade
I got mine cut over ebay. You just take a photo of your blade and they cut it and post it out to you. Then you just swap the blades over in the flip key. Cost me £7 and I received it next day and worked perfectly![]()
So you let someone cut a key blade for your car then send it to what i presume is the address that you keep your car at, wouldnt be me
It won't unlock the car without the transponder and they would have to try and guess which car is mine. They are an established locksmith that others have used. I presume you wouldn't let a locksmith change the lock on your house in case they broke in?![]()
