Flip Key
Andy The Bubble
Andy The Bubble
Mar 1, 2004
51
London/Birmingham
I have got a hold of a VW flip key. Obviously I have to change the blade. But apart from that should it be compartble.
(My car also has remote central locking), So i would also need to get this and the transponder programmed
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
change the blade for one cut to suit (hope yours is a late one)
remove the chip and refit your original one to start it
and as for programming the remote - you'll need to replace the internals as they run at a different frequency
not impossible - but not a plug n play job
Cracking idea mind :p
chisel
265
look at the mk3 section, there is a lot informations ....
1. remove the badge
2. under there is a small screw
3. remove the transmiter
4. put the transmitter from your old oryinal key
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
the immobiliser part is either a small black chip about 5mm*10mm/3mm or a small glass tube about 10mm long and 3mm diameter
that bit only works the immobiliser in a passive fashion (needs no power/control just be within range of the column on starting)
the remote (locking) section is the hard (poss) bit as it needs to be modified to suit the later key - but not impossible
the blade can be cut short and some drilling/pinning is easy to adapt
NOTE:
sounds daft but hook the flip key to ya keyring for a week as they are a pain in the pocket imho and the mk2 column doesnt lend itself too well to a heavier/longer key really
have a good look at it before you dive in - nice gadget but not really a must have mod
cupra44
260
mine works perfect too all i did is get a alhambra key and a new blade cut, Runs on a 433.92 frequency
SWANSWAY CUPRA Dealership
