CupraTurbo81
Hey guys been doing some cheap mods to my Cupra recently and decided to do something about my broken near side fog light. Had a wee idea for it!!
I first of all removed all the broken glass with pliers and scraped away all the sealant used to hold the glass in. Now as this unit is sealed a took a hack saw to the back and opened it up where I was able to remove the entire light out just leaving the casing.
Now with all the sealant holding the glass removed the plastic insert in the front just popped out. I then put it back in the other way around using a wee bit silicone to hold it in
Then gave it a wee coat of black paint then screwed it back in place and clipped the cover back over it. I have a temporary pipe attached to it using some cable ties at the moment but will be getting some proper stuff shortly.
Not a bad wee mod at no cost and am thinking about doing it to the other side for my IC but that one isn't broken and don't want to destroy a perfectly good foggy. I have it removed just now and just have a gaping hole which I guess will be equally benificial to air cooling, just looks a bit naff. Next im going to paint my seat badges black and i'm also working in making something to hold boost and oil pressure guage in centre air vents.
