Gar512
Sweden
Hello,
I live out on the countryside in Sweden and I think that the high beam is to narrow for the small country roads. I have seen that you can modify your fog lights so they will turn on when you activate your high beam on your car.
Does anyone know how to make the fog lights turn on together with the high beam when you select the "auto"/"DRL" function on the light switch? I would like to have have the option to only activate the high beam (not the fog lights) when I turn the lights switch all the way to "on".
Hope you understood what I am trying to do.
//Martin
Hi Martin, I think what you want is done via VCDS cable or using the Obdeleven app. I will mine set up this way ie fogs come on with high beam and off when dipped.
Sent from my Pixel XL using Tapatalk
Ah, Thank you! Did not know where to start digging but now I have a found a LOT of info. Looks like the OBDeleven might be the easiest way to get there.
