I have heard that when you get your lcr remapped you need to upgrade the spring in the forge 007p, some people on this site seem to have not needed to do this. how can i tell if i need to do this ?
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
alrite then smart ass !bigjode said:Ring forge - they have them in stock for next day delivery. Theyre just not on the site. Think about it, How could anyone else have them if forge don't - and they're the manufacturer![]()
SoLiDSnK said:I'm running the red one...
forge said:
bigjode said:I had my LC remapped and the car was surging, i guessed it was the boost dropping off part way through the rev range then building up again.
I went down to Forge today and bought a spring kit and swapped the std green for yellow - the surging has stopped 99% now and the only thing i did was change the spring.
I think the idea is that the green one can't always stand up to the extra psi in a remapped car and can't keep the valve closed, so it dumps the boost prematurely. It hasn't happened to everyone though.
1 question to the man from forge though is how do I use the spacer thingies that the kit comes with - it says its like a halfway stage between two springs?
