yaza01
51
Hi all finally found the broken wires for the right hand side tail light and fog light in the boot
Can anyone give me a wiring diagram as i can not find the other end of the broken wire
The rest of the wires in that loom
Lead to a connector as pictured and leave the other end but the broken wires have no wires on the the connector
All help appreciated
Wiring diagram below (click its header bar to enlarge).
The broken Black/Blue wire is for the fog light on the right-hand side (L47) and it changes to a Grey/White wire after connector T5/g. If that broken grey wire is actually Grey/Yellow then it's for the tail light on the right-hand side (M2).
It's not clear what that white connector actually is in your pics but it can't be any of the 3 "T5" connectors in the wiring diagram because the connector isn't black or brown and it has wire colours going to it that don't match the ones going to the "T5" connectors in the wiring diagram.
J519 is the Central Electronics Control Module (CECM) and it is up under the dashboard above the pedals. The connectors are under the relay carrier as indicated by the arrow...
The fog light wire from L47 (Black/Blue) goes to pin 3 of connector C (Grey/White). The tail light wire from M2 (Grey/Yellow) goes to pin 10 of connector C (Grey/Yellow).
Cheers fella ur a star all sorted thank you again could not have done it without the diagram and info
