May 19, 2026
Hi all,
Looking for some advice on a 2018 SEAT Ateca 1.4 TSI EA211 that has developed ongoing EPC/start-stop faults after a coolant wiring contamination issue.
It started with:
  • EPC light
  • Limp mode
  • Start/stop error
  • Reduced power
Original codes included:
  • P261C
  • P0034
  • P0641
  • P0237
  • P2562
  • P0122/P0222/P2122 etc.
I eventually found coolant contamination/corrosion in connectors around the turbo area. A mechanic later diagnosed a leaking coolant temperature sensor that had wicked coolant through the wiring loom.
So far I have:
  • Replaced the leaking coolant temp sensor
  • Replaced the auxiliary coolant pump
  • Cleaned ECU connector thoroughly
  • Cleaned affected connectors with contact cleaner
  • Inspected loom for obvious corrosion/damage
  • Checked MAP, throttle body, turbo actuator, oil pressure valve connectors
  • Battery and grounds seem OK
The car now drives mostly normally, although still restricts power a bit and:
  • EPC light and start/stop error still return
  • Codes currently are mainly:
    • P261C
    • P0034
  • Codes usually return after restarting the engine
  • Cleaning/reseating ECU connector temporarily improves things
One ECU pin was also found slightly bent outward at one point, so I’m wondering if a female ECU terminal may now have poor contact tension.
Before I go down the route of loom or ECU replacement:
  • Has anyone seen coolant wick all the way into the ECU connector on an EA211?
  • Did cleaning/repairing terminals solve it?
  • Has anyone had ECU driver damage from this?
  • Any known shared circuits/grounds between P261C and P0034?
Trying to avoid replacing the entire loom/ECU unnecessarily.
Thanks!
