Cool. Rich, after getting the belt on and tensioned. Turnibg the engine over by hand a few time shoud even the tension out. With slackening the 3 bokts can it nit move the timing ever so slightly?
Turning the engine by hand won't even the tension.
Once everything is done, water pump etc and your ready to fit the belt, loosen the three pulley bolts and turn the pulley slightly to the right, so the bolt heads are just off centre in the elongated holes, dont worry if you go a little too far, then slightly tighten the bolts, just enough to stop the pulley turning (this saves you holding the pulley when feeding the belt around it)
Fit the belt around the bottom pulley and keeping some tension on the belt, do the right side first, feeding it around water pump etc.
Just a tip, if you have a small idler pulley at the bottom left, refit that last before you tension the belt, it will give you a little extra slack to get the belt on.
Once you have fed the belt around and refitted small idler pulley, loosen off the top pulley bolts again and then tension the belt. You need to get the top pulley bolts as near to centre in the elongated holes as possible, dont worry if it's not bang on.
Once your happy, tighten the top pulley bolts and remove the locking tools.
Rotate the engine fully twice by hand. After the second rotation, line you marks back up and reinstall the locking tools. If the tools fit back in place easily and without having to use force, and your tensioner arrow is still lined up with the slot, doesn't have to bang in the middle, then your good to go.
Hope this helps
