I was of the assumption that 5w40 is just as thin as 5w30 when cold so it would get to intended parts just as quick....
I've had my LCR from new and it's now done 127k. I've always used 5w30, initially Magnatec, then Castrol Edge for the last few years. I've had several cars with VAG engines in the past and never had to top up between oil changes. The LCR is different and has always used a bit of oil from new, about 1 litre per 10k miles (my 20VT Cupra didn't use any!). I've not noticed it using any more now than when it was new. Some high performance engines are designed with slightly looser oil control rings to reduce friction and maximise performance. Don't know if this applies to the LCR engine. My oil always goes black very quickly, did from new. I always thought this was a sign the oil was keeping the internals squeaky clean.
Personally, I would only use a thicker oil if the engine was showing serious signs of wear. Modern engines are designed with very close tolerances and they don't all increase with mileage. In the past I've had experience of Ford engines suffering premature camshaft wear due to thicker oil being used.
