LewMcC
100
Waringstown
I left my car in the uni car park and i came out to see that someone mustve scrapped my front bumper. Does anyone know a good way to fix it? Looks like the paint is completely off
Don't you just hate inconciderate gobshites who do things like that and drive off.
I would try t-cut first to see how much is actually through the paint.
A carefully used touch up stick will hide most of it.
Alternative is someone like chips away or one of the other mobile dent/chip removal companies.
That is my pet hate.......GRRRRRRR
As Deano says a touch up stick can work well. Get plenty paint on then smooth it off with some t-cut when it is dry.
Good luck!
I wouldn't, use T'cut as it's to abrasive for a clearcoat finish, its designed for single stage paint and it'll scratch the remaining clearcoat, better trying a scratch remover first..
I had something similar but on the rear bumper but i used some G3 cut compound with a machine polisher and topped it up with some polish and when i was happy a coat of wax for a nice clean look :)
I can't understand why people recommend chips away.
You wouldn't gloss a door out side in the wind and rain. So why paint ypur car outside.
Paint needs to be applied in a controlled environment. Or as usually the case with chips away it breaks Down a month or two later
Quite a few of our company cars have been sorted by chips away - none have complained yet.
They turn up with a portable work booth and work on the car inside it. Even have IR heaters for faster paint drying.
Agreed they are not cheap.
just got the time to have a good look at it, all but a wee bit of it is right threw the paint to the body work so ill have to have a go with the touch up pen.
Ill take a run over to the seat dealership tomorrow to get the pen and to see what they recommend doing, im raging only had the car 4 months [:@] and this has happened already!!!!!!!!!!
