Front Sway Bar End Size
sambolo
Finland
Hi, I have a seat leon style 1.4 122hp tsi year model 2014(registered 25.9.2013). Im about to lower it with eibach sportline springs(45/40mm) and I thought it would be wise to change the fromt sway bar ends at the same time. The problem is that there are two different part numbers: 5q0411315A which is valid till 04.04.2013 and 5q0411315B which is forward from 04.03.2013 —>. My car is year model 2014 and registered 25.09.2013 so I guess I should go with the 5q0411315B part, but the problem is that with both part numbers I found two differend size front sway end bars, 335mm long and 370mm long. Which one should I go with my car, especially when lowering?
Thank you for any help, I think this is my first post, be merciful :D
