Fuel door doesn’t open
Oct 25, 2022
Hi
Just picked up a used Leon only to realise the fuel door doesn’t open! Had to stick a key to push it open where it looks the following are broken
will I also need to replace the fuel cap door as well as the part with the lock?
any idea how much a dealer would charge for this please?
Damo H
4,714
2,809
Car Length In Front
Sadly the solenoids for the lock do fail, not sure if its a inner trim that needs to come of, or if it can be done when the fuel filler is open.
As for the fuel filler door, I supposed it depends on how secure you think it will still be, I mean if you've managed to get it open anyway? Unless it was already broken by the sellers. A determined thief/vandal is always going to get it open and its never going to exactly blow open on the motorway or anything so likely its fine.
RADIOTWO
489
94
North Derbyshire
Hi
I suppose the burning question is "how was you trying to open it" ? and was the car unlocked ??
Walone
1,559
429
Near Heathrow
Reactions: Damo H and mty12345
