Cupra st 290. Left the fuel go lower than usual before refilling. When filled , still showing empty . Has the sensor managed to get stuck ? Speedometer working.
If you only put 3-5 litres or something, then it may not register (my personal experience) but if you filled it to full, and it's still showed empty...not sure. What does the range say?
Did a search and from what I can see is drive a few hundred miles and refill , this might bring the sensor back to life. Hopefully I don’t run out of petrol carrying this little exercise out!
Same thing happened to me last week. Let the level get nearly close to dry, and filled up and no change to guage. Used the entire tank filled up again it went back to normal, but had to run on an entire tank with the light on!
Never had an empty tank I made it to the petrol station, I just let it go so low, same as OP, that caused he gauge to stick. Jusr for anyone else in the future who has the problem.
