004248 - Intake Manifold Tuning Valve Position Sensor (G336): Open or Short to Plus
P1098 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 39
Mileage: 62341 km
Time Indication: 0
Date: 2000.00.00
Time: 10:44:41
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 26.0°C
Temperature: 24.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 12.192 V
012555 - Low Pressure Fuel regulation: Fuel Pressure Outside Specification
P310B - 004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 16
Mileage: 63150 km
Time Indication: 0
Date: 2000.00.00
Time: 08:44:52
Freeze Frame:
RPM: 1207 /min
Load: 32.9 %
Speed: 0.0 km/h
Temperature: 27.0°C
Temperature: 23.0°C
Voltage: 14.224 V
012599 - Intake Manifold Runner Control: Basic Setting not Completed
P3137 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Mileage: 65101 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 31.0°C
Temperature: 28.0°C
Absolute Pres.: 990.0 mbar
Voltage: 12.065 V
Readiness: 0000 0000
Hullo all! Anyone got any ideas/tips on getting these sorted. I know the Intake manifold runner motor probably needs replacing because I'm always doing the basic setting reset. But the other two are new ones!!! Where do i check the wiring for these other two? I'm not so hot on the spanners so go easy on me!!
Thanks.
PS: Posted this in the vag com section, however either no one checks in there or no one that checks in there knows! So sorry in advance for the re post!!
Freeze Frame:
Fault Priority: 0
Fault Frequency: 39
Mileage: 62341 km
Time Indication: 0
Date: 2000.00.00
Time: 10:44:41
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 26.0°C
Temperature: 24.0°C
Voltage: 12.192 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 16
Mileage: 63150 km
Time Indication: 0
Date: 2000.00.00
Time: 08:44:52
Freeze Frame:
RPM: 1207 /min
Load: 32.9 %
Speed: 0.0 km/h
Temperature: 27.0°C
Temperature: 23.0°C
Voltage: 14.224 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Mileage: 65101 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 31.0°C
Temperature: 28.0°C
Voltage: 12.065 V
Thanks.
