Hi all
As i having trouble with FULL-LED headlight dipped beam misaligned in relation to the other headlight. I've tried to find some solution for this.
Picture show what i mean (misaligned)
You can easily go and cover the LED elements to show you difference
There is actually TPI from Seat to do this under warranty:
Transaction No.:*2037217/1
Release date:*06-Jun-2014
Technical product information 9415, 5F, FULL-LED headlight dipped beam misaligned in relation to the other headlight
Customer statement / workshop findings Customer statement: The dipped beam of the FULL-LED headlight is misaligned in relation to the other headlight (see Figure 1).
Will go to my nearest Seat leave them to sort it out for me. Not sure if this is covered under my extended warranty from JC6000. If not there is other step how to sort this out by yourself
This beam misaligned is due to insufficient tightening of the metal nut on the reflector, causing misalignment of the FULL-LED headlight
This bolts can be found behind cover marked on the picture
So hopefully this will help someone with it as this is just annoying for me.
Do not forgot after correction do the headlight alignment
