moditsteve
Hi there i have a 54 reg seat ibiza fr tdi and im having problems with changing into 6th gear, i try to change and it wont slip in so have to force it, this doeant always happen but happens 60% of the time?
What do you guys recon it might be and how much do you think it is to fix?
thanks
steve :confused:
aye mate if u have been trying to change to quickly the cables will stretch or move thus causing crappy gear change . mines has dun it twice now
Ok, so is it a job that can be done easy enough or is it a garage job ? Any instructions anywhere on how to do it if you can do it ya self ?
i would get it done professionally as it may require re-alignment of gear linkages...
you shouldn't need to be changing gears lightning quick...the TDi's have enough torque to give you the advantage anyway :D
