GFB Divertor valve
leegt5
232
HAs anyone ever tried one of these ??? Supposed to vent 60% to atmosphere and 40% to recirc to keep the maf happy !!
Forbez
Huge Member!
Feb 11, 2004
5,877
S.Wales
Indeed!
Been done, some say it works, some disagree.
Causes engine management lights.
Some people have had no probs, but it seems that it doesnt affect cars that haven't been remapped as much as it affects cars that have been.
leegt5
232
I hate to admit it but Im a little boy racer at heart but don't want to mess up the fueling on the car so not gonna fit something that is going to do so.
From what I have read then if I replace the Bosch DV with a Forge Recirc and install a aftermarket induction kit will I hear any sort of chatter/dump noise without the car being remapped ??
leegt5
232
So the cars that you hear chattering is it because they are running more boost than their DV can get rid of in a dump or is fooked so it being forced back to towards the turbine and causing a chatter ??
May 2, 2006
2,758
no, thats them cars, these cars are designed to vent via the DV, if it cant if falls back onto the wastegate(chatter) , if you dont replace your dv expect your turbo and go bang pretty soon
leegt5
232
So say for instance a 200SX I know, without a DV just induction kit... No uprated wastegate and it chatters why would that be ?? Mind you the boost is higher than standard !!
May 2, 2006
2,758
different engine altogether mate, some can, some cant, these cant
on the 200sx i would think it chatters due to it not having a dv, but i dont know that engine so dont quote me on it
jNx
241
M25 J13
www.surreymodified.co.uk
Soooooooo... What if you want a nice big wastegate chatter?
On Smart cars we just used to wind the actuator on the turbo in 5 turns and it was chat happy!?!
For the Ibiza would I have to upgrade Diverter and Actuator? Sorry for the noob questions
May 2, 2006
2,758
:doh:
if you want chatter, remove your DV and bung the pipe, but i stress i do not advise this to anyone as this will make your turbo go bang VERY quick !!!!!!!!
DO NOT DO THIS ............. CHATTER IS BAD............... VERY BAD !!!!!!!!!!!!!!!!
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
disonnect the vac hose off the top of the dv where it connects to the n249 valve next to the intercooler piping over the engine. SOUNDS GREAT
the only downside is you'll lose half ya boost because the dv opens all the time and essentially vents atmospheric and these engines dont want to...so why bother trying!!!! FFS
leegt5
232
Well Im not trying to vent to atmosphere if its gonna damage anything, just enquiring weather this so called 60/40 things work. If the consensus is they don't work i'll opt for a forge recirc and induction kit !!
Cupra_G
185bhp/230ftlb
Mar 7, 2006
172
ayrshire
s62.photobucket.com
Hey my mate had the GFB on his mk4 golf, it worked ok before he got it mapped but after revo it couldn't cope the spring was too soft and leaked boost. I bought the Turbosmart one you can adjust the spring which vents both ways. I eventually blanked the atmospheric end off! Better just sticking to Forge dv
Forbez
Huge Member!
Feb 11, 2004
5,877
S.Wales
jNx said:
Ahhh Wastegate chatter is quality! Much better than Dump Valves!
There must be a safe way of achieving it!
Do you understand what chatter is?
If not have a read ant then you'll understand why its bad!
Molehill_Mike
Rollin' on 20s
Jan 3, 2005
2,563
Bedfordshire
Alot of people decide to go for the Baileys BV30, its essentially a re-circ valve but is louder than the Forge 007P, I have run both with no problems...its not MASSIVELY loud but you can hear it well... get an induction kit on and an uprated TIP, plus more boost, you'll be in heaven fella :D
Mike
