dannyboi
113
ive got my fmic waiting to go onto my mk1 leon 110 but ive wanted to find a bigger inlet manifold first so i can get my delete pipe aswell then fit the lot together
ive found a inlet manifold off a 02 plate golf tdi gt is this the one i want ? i believe the gts have the 130/150 engine ( not sure if its a pd one ? ) apperently the engine code starts with ajm and the delete pipe says needs to be off a asz or a arl but when i look at pics it will look like it fits but i dont want to buy it all then im stuck ... so thought i would ask you guys for some advise
thanks
I think that engine is the 115PD?
I believe you need a PD130/PD150 manifold. It should be 57mm inlet.. The 110 non-pd manifold is 51mm inlet.
I not sure, but didn't the PD115 use the smaller non-pd manifold?
yes the AJM 115PD came with the smaller inlet manifold. the larger one comes from 130/150/160 PD engines and the part number is 038 129 713 AF
