Immobilizer III:
Some 2001+ Volkswagen/Audi vehicles have Immobilizer III. This works similarly to Immobilizer II, except a secret key code (SKC) is required in order to perform the adaptation routine. The routine changes depending on whether you are using a BRAND NEW ECU that has never been in any other car, or if you are using a USED ECU that has been previously matched to another car.
Immo-3 knows your car's VIN. Access 17-Instruments (or separate 25-Immobilizer on vehicles that are set up that way) and look at the first "Extra" field.
If you see something like: "Immo-ID VWZ7Z0W0648696" You've got Immo-2 (or maybe even Immo-1 in earlier non-US models).
If you see something like "WVZKB58001H231169 VWZ7Z0W0648696" You've got
Immo-3. The first 17-digit string is the VIN. The second 14-digit string in the Immo-ID.
Note: See this page for important SKC information.
There are different procedures for installing a NEW ECU or a USED ECU.
NEW:
1.
Before Installing a BRAND NEW ECU in vehicle, get the ECM
coding from the old ECU in the vehicle
[Select]
[01 - Engine]
Write down the 5-digit Soft.
Coding
[Close Controller, Go Back - 06]
2.
[17 - Instruments]
Write down the 14 digit Immobilizer ID number from the "Extra" field
3.
Take that 14-digit Immobilizer ID number (along with your VIN number) to your dealer and request your seven-digit SKC, along with the workshop code and importer number (all this information can be found in the upper-right corner of the Administration screen of the dealer's VAS 5051). Additional information about
how to find the WSC and Importer Number can be found here.
4.
Install new ECU in the vehicle.
5.
Measure the car's battery voltage, it must be 12.5 V or higher.
6.
[Select]
[01 - Engine]
[Adaptation - 10]
Enter "50" in Channel Number
[Read]
[Use 7-digit PIN/SKC]
Enter the 7-digit PIN, Date on which the PIN was GENERATED BY THE DEALER, along with the dealer's Workshop Code (WSC) and the Importer number
[OK]
7.
VAG-COM will validate the data you have entered and return you to the Adaptation screen, where the New Value will show as "XXXXX".
[Test]
[Save]
[Done, Go Back]
8.
Verify that the VIN now displayed in the "Extra" field matches the VIN on the vehicle code from dealer
[Go Back]
[Exit]
9.
Turn ignition OFF and then back on within one minute, but do not start vehicle for two minutes
After 2 minutes, start the vehicle
10.
[Select]
[01 - Engine]
Verify that the 5-digit Soft.
Coding matches the
11.
[Fault Codes - 02]
Clear all DTC's.
USED:
1.
Before Installing a USED ECU (we'll call it ECU #2) in vehicle, get the ECM
coding from the current ECU (we'll call it ECU #1) in the vehicle
[Select]
[01 - Engine]
Coding
2.
Install the USED ECU (ECU #2) in vehicle, (the Immobilizer light will be flashing, that's okay for now)
[Select]
[01 - Engine]
Write down the 14 digit Immobilizer ID number from the "Extra" field. This the 14 digit Immobilizer ID number for ECU#2.
3.
[17 - Instruments]
Write down the 14 digit Immobilizer ID number from the "Extra" field. This the 14 digit Immobilizer ID number for ECU#1.
4.
Bring both 14-digit ID numbers to your dealer and request both your seven-digit SKC's
Keep track of the SKC for ECU#1 and the SKC for the ECU#2, as well as the Date on which each SKC was GENERATED BY THE DEALER, along with the dealer's Workshop Code (WSC) and the Importer number. Additional information about
5.
6.
With the USED ECU (ECU #2) in vehicle, (the Immobilizer light will be flashing, that's okay for now)
[Select]
[01 - Engine]
[Login - 11]
Enter the 7-digit PIN from ECU #2, Date on which the PIN was GENERATED BY THE DEALER, along with the dealer's Workshop Code (WSC) and the Importer number
[OK]
[Do-It!]
(You just "introduced" yourself to ECU#2 and the ECU should listen to you since you knew
how to login. The ECU is now ready to learn its new home.)
7.
[Adaptation - 10]
Enter 50 in Channel Number
[Read]
Enter the 7-digit PIN from ECU#1, Date on which the PIN was GENERATED BY THE DEALER, along with the dealer's Workshop Code (WSC) and the Importer number
[OK]
[Test]
[Save]
[Done, Go Back]
(You just told ECU#2 that it has a new home, and that it should make friends with the Instrument Cluster.)
8.
Verify that the VIN now displayed in the "Extra" field in the Engine matches matches the VIN now displayed in the "Extra" field in the Instrument Cluster controller.
9.
10.
[Select]
[01 - Engine]
Coding matches the
11.
[Fault Codes - 02]
Clear all DTC's.
