Well I have had many disputes with friends over which panel filter is best I say piper cross others say green cotton just wondered what are your views on which one is best?
Avoid oiled foam filters like Pipercross and Ramair as they can mess up the MAF meter - green cotton, Jetex or K&N should be fine.
Jetex outflows Green.
I have the logs to prove that a Jetex cone outflows a Green Cotton panel filter in a smoothed/drilled airbox when fitted to a stage 1 remapped car, this would not happen if I were already getting optimum airflow from my previous setup. I agree that there is no point in having an air filter that is rediculously over sized but with cars turbo charged cars that are mapped to run a higher boost some setups are definately better than others. This was certainly the case with me.
You've demonstrated (but not proved) that one system flows better than another, however you've missed the point. The discussion was related to one filter type vs another. Was it the filter or the airbox that restriced your flow previously?
Do you actually know what your peak airflow is?
How do you know your current system still isn't restrictive? (But less so than previously)
Also, is your cone part of a CAI system or does it sit in the engine bay?
