gtrs eliminator?
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
log into engine control module with vagcom and the ecu number is reported top left.
6K0 as std ibiza, 8N0 a possible early S3 equivalent code they'be used in the 512k box
(same as Jabba's base file for IHIs in ibizas)
IbizaAlex
AKS tuning
May 11, 2008
532
Bedford
Looking at the fueling, its running about perfect (as in under 0.80v) at the lower revs, then its jumping to lean (above 0.80v) as it revs higher. That can cause the higher 'CFs'. 0.80 volts is perfect when at full beans.
All i can say is the map needs adjusting.
Nov 2, 2004
9,335
South Wales
Its a narrow band tho so it wont give accurate a/f readings as the voltage switches as its only accurate over a small range of AFR around stoich.
Either get a wideband or forget block 031.
ian_cupra
he had a big spike at 4k, the eliminator isnt that much more laggy, looks smoother though
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
boost for boost same comparison then to make sense of it all
it will be airflow related (exhaust manifold and turbo intake) I believe
