pikzibner
As you know I changed my IC with bigger and I got a big lag. After a remapp it was a little bit better but I wasn't sattysfied. Now I decided to put back the old original Fabia RS .IC And it's the same. Car pulls from 3000 rpm. I don't know what it is. I can hear turbo start sppining at 1500rpm but nothings happens. I checked the pressure sensor and I think it's ok. Even cleaned and closed the EGR valve. On the dyno it's claear that I lost the torque. The torque rise like power. I have 158 HP on 3930 rpm and 295NM at 3700. Before torque was 340NM an 2200 rpm. I have no leak. What should i check next???
