After the recall and reset to factory I re enabled the one touch mirrors.
I also set the number of windscreen washers before headlamp washers from 5 to 15.
I left the delay as it was 500 ms [Microseconds! or was it 5000]
However testing yesterday the first use of the Wipe wash activates the Headlamp washers then not again [did not get to 15 ] Later on second drive it did it again first use wash wipe activated headlamp washers with no lights on]
1} Question is that normal even with headlights off the Headlamp washers activate.
[I thought it was AFTER 5 or 15 not starts then counts down and ONLY if they are ON.
2] What is the delay for and what should it be is it MS [microseconds]
If my system is now coded wrong how do I reset it or just revert to 5.
3] When using Carista with ignition on should I have left lights on AUTO or ON or just OFF
WOW sorry cheers Guys
