choppy69
73
Hi
vf 34 Turbo has lost all power does not show on the boost guage and there is no power?
from what I remember last time there was lots of smoke but at the moment there is only a little bit when I first start the car?
These are the codes from vagcom
VAG-COM Version: Release 409.1-S
Control Module Part Number: 8N0 906 018 H
Component and/or Version: 1.8L R4/5VT 0004
Software Coding: 11510
Work Shop Code: WSC 00000
Additional Info: VSSZZZ1MZ4R014892 SEZ7Z0C2135730
6 Faults Found:
16396 - Bank 1: Camshaft A (Intake): Advance Setpoint not Reached (Over-Retarded)
P0012 - 35-00 - -
18041 - Shareware Version. To Decode all DTCs
P1633 - 35-10 - Please Register/Activate - Intermittent
16727 - Shareware Version. To Decode all DTCs
P0343 - 35-10 - Please Register/Activate - Intermittent
18047 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal
P1639 - 35-10 - - - Intermittent
16712 - Shareware Version. To Decode all DTCs
P0328 - 35-10 - Please Register/Activate - Intermittent
16621 - Shareware Version. To Decode all DTCs
P0237 - 35-10 - Please Register/Activate - Intermittent
Maybe have a good look around the engine first.
It could be a boost or vacuum pipe.
Any strange sounds when the car starts to boost?
Thanks for the reply mate I had a look around the engine and underneath but couldnt see any loose pipes ect.
also quite a bit of smoke when it first starts but it goes after a few mins?
no boost at all and no funny noises either?
Could the actuator be stuck if so where do I find it and does anyone know how I can fix it?
