Remote Control Programming 1997 on. (without VAG-COM)
1. Switch ignition ON and leave the key in ignition.
2. Mechanically lock the vehicle using the drivers door using a second key.
3. Press the remote control unlock button once and the horn will sound once.
4. Wait 6 seconds and press the unlock button to activate the
coding procedure. The remote will now be programmed.
NOTE : If you are programming additional remotes the procedure is the same except you press the unlock button 2, 3 or 4 times (with a 1 second interval) depending on how many you have.
5. Switch ignition off.
6. Remove key from ignition and check operation (just in case )
