ive got the pdf too but aint got a solderin iron n not that great wiv them neway. i live in nottingham.
send it to hooch he will do the conversion for you , not sure what he will charge though but least it will be done rightive got the pdf too but aint got a solderin iron n not that great wiv them neway. i live in nottingham.
send it to hooch he will do the conversion for you , not sure what he will charge though but least it will be done rightIt was abit tight getting it in so removing some of the siding could be a good idea, just be careful to mount it how you want it (central etc).
Wiring was pretty easy.. had the standard wiring you'd need for a standard headunit fitting but connected the wires to the correct wire on the center console. Be sure you wire the power source cable of your headunit to the same wire as the center console so when you put the key in and turn it the memory kicks in and loads the unit.
If you get stuck with the wiring side ill draw up a diagram or remove mine and take photos for you![]()
Cheers mate, i think id rather leave the sides as they are even if it is a tight fit, i thought it might not fit all together.
Im not planning to do it straight away anyway but when i come to could i pm you to get a wiring diagram and any photos etc? as thatd be really helpful
if you stuggle to build it aswell then give me a shout![]()
Does anyone know about the wiring? I plugged the brown and black plugs into my new DVD player in my dash, and its only the coloured plug left in the tape deck, but now my head unit doesn't seem to have any power. Does anyone know what needs to be done to get it to work so I can work my aircon?
Take a live from the battery and fit an earth to one of the bolts in the bulk head under the dash and just leave the main power plug in the original unit.![]()
