I guess the only thing you could do it get some clear sealant and try and put a thin layer on so it doesn't look obvious. Otherwise its going to be pretty expensive to replace it!
i couldnt make out the crack from your picture how big is it? an yh it will keep on fogging up unless you seal it or replace it. what i did with mine was heat up the end of a flat head screw driver then melt it back together then use a hairdryer to remove all the moisture. it wont be the prettiest of things but its cost affective an looks a dam sight better than a fogged up head light!
Maybe try and get a used headlight from scrapers and change headlight covers.
Not that hard to do, use a heatgun / hairdryer to heat the sealent around the lense and prise off.
Did it on a mates polo years ago and vinyl tartand the inside
