headlight cracked
Lela_CRO
83
Split,Croatia
Is it possible to repair this crack on the headlight?
it bothers me that headlights is fogged
Dec 28, 2011
1,250
Cairo, Egypt
I can't really see it well from the picture. Is it a crack on the top of the projector lens itself or a crack on the bottom of the headlight's cover?
Jarre
5,365
11
Stockton-On-Tees
I guess the only thing you could do it get some clear sealant and try and put a thin layer on so it doesn't look obvious. Otherwise its going to be pretty expensive to replace it!
Lela_CRO
83
Split,Croatia
If I dry headlight it will fog up again because that "small" crack....probably ???
I should fix that stupid crack first? But I do not know how to fix it,if I use silicone it will be ugly and visible
Ryan.
61
i couldnt make out the crack from your picture how big is it? an yh it will keep on fogging up unless you seal it or replace it. what i did with mine was heat up the end of a flat head screw driver then melt it back together then use a hairdryer to remove all the moisture. it wont be the prettiest of things but its cost affective an looks a dam sight better than a fogged up head light!
Ryan.
61
on my old car i had somthing like that but it didnt look like that after!
Lela_CRO
83
Split,Croatia
this picture is for windscreens
if I leave this crack like this on headlight it will always be fogged...crack like crack doesn't bother me only fog
May 20, 2010
564
skipton north yorkshire
Maybe try and get a used headlight from scrapers and change headlight covers.
Not that hard to do, use a heatgun / hairdryer to heat the sealent around the lense and prise off.
Did it on a mates polo years ago and vinyl tartand the inside
