Tuesday the temp gauge warning flashed and beeped but the temp was fine so stop at first garage and the water in the expansion bottle had dropped.
Water below rad so thats the fault, no biggy and its being sorted tomorrow with a new rad funnily enough (core leaking, no damage - corrosion).
Any way because I've been having me head under the bonnet regularly you get to have a look around and I have found something you all may wish to check.
At the front of the bay there is an aircon pipe which comes from the washer bottle area, 90degree bend up towards the bonnet and then it is looped back down in to the bay.
On the loop it is very close to where the bonnet release wire runs and a few electrical wires which are protected. Now on mine the loop has been rubbing against this protection and worn a nice groove in the pipe and it is down to the inner nylon core so I don'tthink long before it splits!!!!!
Will have it looked at tomorrow when its in and try and get it replaced...
