sjoyce666
28
I have a heated front windscreen in my 2003 Alhambra SE TDi 130
A few of the lines do not seem to be working. Does anyone know of a way to fix this or can it only be fixed by fitting a new heated front windscreen ?
Also when should the heated wing mirrors work ? Is it only when the heated front windscreen is on ?
Usually the heated door mirrors come on with the rear heated screen control
For a front heated windscreen you will have to get it replaced, as you can't fix them according to AVfourms. But you might be able to get a repair kit from halfords if the rear was to go. As said before by others the heated mirrors come on with the heated rear windscreen button.
Yup! 100% all responders! Mirrors def heat with rear window heater!
