heated washer jets & pipes
Jan 22, 2007
2,074
some may say lala land....
will do andy hoping it works.easy to do...
can't wait to see under scuttle panel and see a mass of wiring and none are related :)
[edit]
screen wash has always been halford blue
mot seen need to by different as always done the job for me.
[/edit]
[edit]
just looked on etka, called gf to turn home pc on :)
looked at the part number offered by phillc and looks to have a lug on it.
hope they are easy to swap over now! in the freezing no chance of feeling fingers weather...
Has anybody changed these to know how easy or not it is remove them?
[/edit]
Andrewcupra TDI
Resident Desk Jockey
Apr 30, 2008
3,282
in the mountains ( Wales )
no ideas mate , there was a thread kicking around for fan sprays from ibizas etc
as for screenwash the more neat you put it the better protection you get even down to fully neat stuff
cant advise on paintwork tho ,
dave_ph
Jul 12, 2006
411
Somerset
www.vagowners.co.uk
let me know how you get on with changing your washer jets, as yesterday morning i had my passenger jet freeze up so only half my windscreen was getting cleaned! I stopped at the services, sprayed some de-icer on it and it worked fine after that!
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
Its really easy too change the washer jets, and there's no wiring under the scuttle panal, just the water hose you will need to retro fit the jet wiring, or find a wiring diagram. i have changed mine to the fan type and i have had no problems with the washers freezing dont know if its just luck or what.
matt_s
4 8 15 16 23 42
Dec 23, 2004
657
19
Stop using the ready mixed screenwash, it's rubbish. It even stained the paint on my van plus it always goes streaky.
Jan 22, 2007
2,074
i use the ready mixed from halfords and have had absolutely no issues ever at all.
guys, i have the new heated ones, but bonnet is being an arse. catch releases but still stuck so cannot open.
Will try and look at changing tomorrow, after soaking in wd40 in the morning
matt_s
4 8 15 16 23 42
Dec 23, 2004
657
19
just that this morning it took nearly 35min to defrost so i could use them.
Halfords blue one to be exact. should stay liquid to -5 on the bottle and no idea how cold this morning as the onboard temp gauge needs 5min to get an accurate reading and it only said -4 anyway
I'd say that the screenwash freezing was an issue. A dangerous and potentially fatal one.
Jan 22, 2007
2,074
looks like the bonnet release mechanism is feck'd.
[edit]
fixed for now, after good douse of wd40
[/edit]
need to remove scuttle panel, so of too research.
not looking a two minute job anyway..
Andrewcupra TDI
Apr 30, 2008
3,282
well had a memory card of another member nate
and on there was some diagrams
if any help
Radeonuk
42
Can you get heated fan jet ones? or are these just like the oem 2 jet type but heated?
Does any one have a part number for heated fan jet type? like the Ibiza?
Jon
magicoi
254
Lincolnshire
so whats the easiest way to access the pipes under the jets then? Either the hose has come off my jets or the hose has split!
