Jedimaster65
Searching for a clear lap
Aug 13, 2007
786
Cheshire
Hi guys, I am trying to find a rattle, and want to take the glovebox out - so need to know what the correct procedure is, especially given it's proximity to the airbag...advice and pics would be a big help, thanks. :)
If you are doing it by yourself, there are 5 screws holding it in. 3 on the upper inside edge and 2 behind the golvebox all are easily accesible.
Just one point if you have PAD make sure you disconnect and reconnect the switch while the igintion is off otherwise you will get the airbag warning light on.
