It has now decided to work again... But I will monitor it
The car struggled to start... Almost as if the battery was drained. Maybe it's way of conserving power was to limit the window function? However all other windows worked fine
I had a similar window problem, try doing a window reset before you start thinking about changing switches/motors.
Think you hold the window switch up for 10 seconds then press it down for 10 secs and it resets it.
Have a search on here as someone posted the technique recently
