Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps.
Need any help or pics that will guide me through fitting my TIP on my fr, done a search and nothing came up. Im as far as removing the old rubber one, now stuck with the big metal section that goes into the turbo.
its probably easier to get at the turbo end from underneath if you have a jack and axle stands. If you'd rather not do that, then remove the airbox, that should give you enough room the amount of times I've had my TIP on and off is ridiculous, I can do it in 10mins now lol.
cheers peeps, managed to get there in the end. Still got my boost problem so now onto something else. Thats me replaced the DV/TIP and Pipe from intercooler to intake. Fault was showing up as low pressure detected (check d.v)
Could be a n75 or a handful of many other things! only money and time will tell, all parts needed up-rated for me to go to stage two anyways.
