HELP! Jacking points
Hairy
590
Wiltshire
It's a common problem, if you do a search you find a few tips, I just don't take them off any more. (and use a trolly jack instead)
Cupra_Mark
71
South Wales
The Cupra Kid said:
...how the hell do they go back on!!! I've left them off and feel a trip to the dealer as soon as they open in the morning!
Took one off before, never again! Yes invest in a TJ, a lot easier I reckon!
By the way, did you sort you car problem out in the end! If so, what have you got now?
Mark.
Ju.
461
Bradford
I've had mine off loads of times and never had a problem putting them back on!!!
Make sure theres no dirt build up around them , clip the top part in and then a quick up wards tap with the palm of the hand on the bottom and voila :p
ChrisUK
Eat My Smoke
Oct 20, 2004
2,258
Liverpool, UK
THe very first timeI took these off, I had a nightmare getting them back on (ended up usnig a knife to jimmy them back in !).
I took all 4 off over the weekend to paint my calipers, and I can say that they took less than 2 mins to put them all back on - I was shocked - lol
Put the 2 clips in at the front (plus the rubber bit), then slowly push the cover back onto the rear clips, then smack it with your palm !!!
Worked a treat :)
BHP Addict
Back in a SEAT!!
Jan 31, 2006
886
Birmingham
Been LCR owner for 3 mnths and I have now experienced this problem.
I was propa stressed. I threatened it with cuting the wire thing that holds it on and one more go it was done.
I think they are scared of me now :lol:
The Cupra Kid
A member since the start!
Jun 16, 2001
280
Now in Lincolnshire!
LOL, glad to know its not just me then! I was at the dealership this morning and explained my problem... no problem sir, give us min and we will have them back on....
30 mins later... OK, i NEED to get to work now! They had no idea how they fit! its booked in Saturday again...how stupid can this get!!!!! I've just had another attempt...no joy!!! F**KING THINGS!!!!
Oh yeah, i need to update you on my saga on the exchanged LCR... I will post up a thread!.....
EU03 LC
Had the same problem - solved it by taking the whole side skirt off. 5 Torx head screws, 1 in each wheel arch - 3 underneath. Once off it takes seconds to clip them back on. (Now use TJ!!)
The Cupra Kid
Jun 16, 2001
280
update on the saga....
NOW FIXED....YIPPEEEEEEEEEEEEEEE
bit of a hastle tho, went back to dealer as agreed this morning...problem was they had no idea I was coiming in, even tho it was booked in on tuesday...or so i was told! 4 more people tried there best...1 from service dept and 3 from the body shop...NO IDEA!!!! waste of f'ing time and was told the skirt needed to be taken off!!! i dont think so! Its needs to go back sometime soon for other bits to be sorted and was told they will sort it then!
On the way back home stopped off at my trusted old dealer for advice on the wasters im dealing with at the mo... what a star he was...one look at it and 30 sec's later all done! Why cant all dealerships be like that... GOLD STAR TO HIDSONS SEAT RAINHAM
Cuprabob
89
LOL, we've all been there changing a wheel in the pissing rain and eventually having to pull out the grommet with the plastic safety wire so that you can drive home and fit it later.
God knows what the designers were thinking. I found if you clipped it in at the front and then pivoted around pushing the back up and then push the clips up with a small flat screwdriver they just clip into place.
Why could the designers not have them sliding in ???
My new R32 has sideskirts and it doesn't have any stupid covers
The Cupra Kid
Jun 16, 2001
280
you shouldnt need to take the whole bloody skirt of to fit them back tho! I know next time what to do now.. a trip to the pound shop and invest in a rubber ended hammer is on the cards!
Mister_E
87
Where do you boys jack up from using the trolley jack?
I tried to get the trolley jack under the FR+ and ended up using the scissor jack on the side and then jacking up at where the shock meets the wheel (wishbone?) with a piece of wood on the end of the trolley jack! Ended up jacking with the TJ, the the Scissor jack and then the TJ again...gotta be an easier way of doing this!
Hairy
590
Wiltshire
Are you using the std jack to get the clearance to get the tj under? If so just put a piece if wood or a couple of bricks in front of the wheel and drive onto them, tj should then fit under the side ok.
