Fox1980
32
Hi All
I will be replacing the front brakes soon and would like to raise both front wheels together and place axle stands under the reinforced pinch welds.
Does anyone know a suitable central jacking point to lift the whole front end?
I do not want to risk raising each side one by one as I can see the first axle stand shifting in this situation.
Thanks in advance.
Hi All
I have successfully changed the brakes today.
I jacked the first side at the rear pinch weld which lifted the front to enable an axle stand to be placed, I lowered the rear back down and jacked the other side from the bolt on the subframe which holds one side of the botton suspension arm. No issues.
