welsh frtdi
smokey
Oct 3, 2009
65
carms
guys i in a situation where my clutch has gone to grave and i got gearbox on the deck of my garage.. i need to find out if fitting a standard flywhhel(lightened and balanced) is ok to do rather than a dual mass.. i tried searching for answers on net but someone i know in vag dealer said they cause vibration and harsh comfort in clutch. i jus need any answers to what i should do.. i have both units to choose from byt dual mass is supposed to be unreliable when tuning to over 200bhp which is my intension:help:
AFAIK, fitting a Single Mass Flywheel (SMF) causes a loud chatter through the gearbox at idle with the clutch pedal up. Noise goes when pedal is pressed and clutch is disengaged
I know that on the Fabia's, you can raise the idle speed slightly using VAG-COM, which helps to reduce the noise somewhat.
Benefits are better pick-up from low revs, revs easier and can handle more power
Hope that helps
intensions are highest bhp tdi seat in wales maybe get it featured(seriously)this car has got potensial but gonna throw some silly cash at it then nurburgring by end of march 2011
but jus wanna get drive train done properly as i aiming for maybe 280bhp by december and cant be arssed to keep pulling out gearbox cause of that dmf.but if it will handle 240 ish ok then a dmf will do me till the major mods begin
