gregdaisley
Hi all, can anyone help me with this...
I had VCDS 10.6.4 fully working and yesterday it asked me if I wanted to update to the new 11.10.1.
I hit update which downloaded and installed the new version, I then set up the COM port (USB) for the cable/interface, then hooked up to the car.
Opened the programme in the usual way, I noticed on the home screen it said -1 codes loaded, I instantly knew something was wrong as it normally says around 13,700 loaded!...
I then clicked Select Control Module and an error message popped up saying codes.dat?
What do I do? Re-install the old version that I have on a disc and leave it at that?
Help meeee pleaseeeee!!!
Greg
Not that i use VAGCOM but using the knowledge the older version works you should go back to it.
Perhaps try re installing the new one again
If its a genuine cable, cant you go straight to rosstech for support? Otherwise rolling back the version would probably fix it, yes.
