Okay, so I think that this sensor is an achilles' heel of VW TDIs. It can go faulty after 40k kms or never. Mine happened after 130k. I started the car up in the morning with coils flashing, so limp mode, with start stop system fault. Restarted the car and it disappeared. Since I was in a rush, I did diagnostics during driving, foudn out that this sensor is bad, do not do that. The car was okay, but after few hours coils came back. So cleared codes and drove, then I had time to play with it, I played with the cables, but didn't disconnect it, just tried to click it more in place, (hope u understand me, not a native speaker) and probably that did the trick and it didn't happen again. The swap was really a 5 min thing, unscrew, unplug, take it out of the tube and out with the old in with the new. Actually I have no idea what it does with turbo, imo it checks if there are no leaks in the exhaust system, since it is a pressure sensor. Honestly it's another electronic thing, that does nothing but throws a fit when it goes out, but since it is in the car, replace it.
Sent from my SM-A725F using Tapatalk
