Help! tyre sizes?
G223
303
What tyre size should i fit onto a 6J 16 ET38 its replacing a 175/45/R13
I dont intend to lower the ibiza or any modifications to the arches atall.
Thanks,
Will
MarkJ
Ibiza GTi
Mar 26, 2007
437
Chesterfield
me 3
markj you have the mk3 cupra alloys too, is it the same pressures as the original? i.e. 36psi all around is good?
I'm sure my original 185/55/15's were only meant to be 32/33, not sure what it was on the original 16's. Now i run 33 on the front and 34 on the rear, not sure why but they seem spot on to me. Probably best to ask in the MK3 section if you want to know exactly what they are meant to be, can't see 1/2psi either way making that much difference.
G223
303
i take it all your cars are lowered slightly???, ive been told ill have a jeep rather than a car lol
Mckellar
i used to run about 45psi in my stretched rims. if i went to 30 and took a corner fast i recon they'd slip off!
