Optimus Prime
Hi Guys,
Having had the leon cupra R (2003 210bhp) for almost 3 months now I still cannot get use to its handling
. Basically within the first 2 weeks of having it I had it Custom coded and the filter and the forge 007 valve fitted. Also upgraded the brakes with Ferrodo DS2500 pads (back and front) and EBC Discs front and standard disc on the rear with Motul brake fluid. I find that in the rain the car feels a bit twitchy the rear end moves and the traction light comes on. I took it to Seat who said the OS lower ball joint need changing (explains the knocking noise and the front) and the front Anti Roll bar needs replacing (the mechanic showed me on the ramp and there was a small mark 2 cm long on the Roll bar, does not seem like it needs replacing to me
The car has 2 Goodridge tyres on the front and 2 Kumho's on the back. Both tyres have loads of tread.
I just need your opinion on should I change the Anti Roll bar as said by the Seat dealer (i would probably upgrade them both) or should I change all 4 tyres to the same Better brand and then see how the car handles. Also when I accelarate hard (NOT from standstill) I find the car Torque steers is this normal with a custom code, can this be prevented?
My last 3 cars were E30 M3'S so were all rear wheel drive and normally aspirated so maybe I just need some driving lessons
as this is the wife's car and I get to use it on weekends.
Also can anyone recommend a Seat Specialist near Beaconsfield who could change the lower ball joint and depending on what you guys advise change the anti Roll bars. If there is anyone who lives locally and has a Leon Cupra R maybe we could meet up and see what you think.
Sorry for all the questions but this forum is a very knowledgeable so I just wanted your opinions before I go and spend more money on the car.
Sunny
as this is the wife's car and I get to use it on weekends.Also can anyone recommend a Seat Specialist near Beaconsfield who could change the lower ball joint and depending on what you guys advise change the anti Roll bars. If there is anyone who lives locally and has a Leon Cupra R maybe we could meet up and see what you think.
Sunny
