Help white smoke
Ash jacko
cupra all the way
Apr 10, 2012
163
burton-on-trent
My Ibiza cupra has just started smoking on gear change doesn't do it all the time only when giving it some on the od occasion my mate says its a BIG cloud anyone got any ideas ? Doesn't do it just sat on the spot reving it
Jul 4, 2007
1,674
bristol
Well worth looking at the dump valve I had this issues once and it was the forge dv leaking slightly. If not get compression test and headgasket test. And mayonnaise on the oil dip stick?
mk1kid
95
west mids
Maybe turbo oil seals starting to go or valve stem seals I'm a mechanic if you need any work pm me bud cheers also got a ko3 with 77k on as upgraded to gt28
yellonvi-R
4,321
birmingham
Sounds like turbo but check as said the dumpvalve. Ko3s up for grabs here ;) but joking aside. Hope its not your turbo as thats just a pain.
Ash jacko
cupra all the way
Apr 10, 2012
163
burton-on-trent
Cheers mate I would rather it be turbo than engine tho. I've took the dv of and cleaned it out seems fine it's got a green spring in and I'm boosting at 18-20 psi is that the right spring ?
Ash jacko
cupra all the way
Apr 10, 2012
163
burton-on-trent
Just had a word with a company they said could be headgasket and there is a bit of pressurising in the water system so gonna do pressure test on bores later bad times :(
Ash jacko
cupra all the way
Apr 10, 2012
163
burton-on-trent
I've done a snif test on it and seems all good so think I can rule headgasket out ( thank god) and I've turned turbo down a bit doesn't seem to be doing it now so might have cured it wish me luck lol
