help wiring up amp!?
hon_n_gem
Candy White K1
Mar 22, 2006
1,132
Kent
www.auto-tuner.co.uk
Hi, heres the situation:
Decided to fit my old system into my car (sub and amp!) seeing as its just been sold. so ok, bought a new wiring kit. power cable, phonos, control, earth have all been laid. Ok fitted the amp to the subwoofer, however on testing nothing turns on!
Ok i have earthed it to an earthing point behind the rear passenger side clusters. Tested the control cable with alternative one, still no luck.
What am i doing wrong?!
By control do you mean remote off of the back of the head unit wiring? On some amps you have to put the wiring in the amp in a certain order, normally earth first. Also is there a fuse that could of gone either in the power cable or in the amp?
hon_n_gem
Candy White K1
Mar 22, 2006
1,132
Kent
Cheers for the advice although..
checked all the fuses, they seem fine, also checked the head unit settings and all subs bits are on!!
and yes by control i mean remote wire..maybe i used the wrong wire......
hon_n_gem
Candy White K1
Mar 22, 2006
1,132
Kent
well, the idiot that i am, i wired the remote from the amp to 'external amp control wire'.
However on further inspection i realised that there was another wire called 'power control' this wire then indeed worked! (im an idiot)
Many thanks for the help guys....
just gotta get all the crappy vibration noises out now!
