tomsf1
Hello all,
I have a 2001 Leon 1.9TDI 110 with 102k miles that is a little bit ill.
Drove to work fine, parked - came out for lunch - traction control light stayed on the car would not start, turns over but nothing else. I called the RAC who fitted a lead running from the battery to the stop solenoid - this clears the warning light and the engine starts.
However, when the lead is connected the car starts but it runs with no power - it can still do motorway speeds etc but it takes forever to get there! The accelerator seems to work as normal for the first 10% pushing the pedal past 10% either has no effect or can make the car slower.
I have taken the car to Seat who just said it the ECU and quoted £1100 fitted! I got the impression they're assuming it is rather than know it is. I have connected VAG-COM and got the results below.
Does it really look like the ECU? Anyone know where I can get a cheap one? Or could it be something else like the MAF?
Thanks! Tom
Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 D
Component: ASR FRONT MK60 0103
Coding: 0021505
Shop #: WSC 00001
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication
Address 08 -------------------------------------------------------
Controller: 1M0 820 043 D
Component: 1M-CLIMATRONIC X0605
Coding: 00044
Shop #: WSC 06441
No fault code found.
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1M0 920 901 B
Component: S5-KOMBIINSTR. VDO V03
Coding: 05412
Shop #: WSC 00476
IMMO-IDENTNR: SEZ7Z0Y0766045
1 Fault Found:
49-00 - No Communications
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06441
1 Fault Found:
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 AH
Component: 8N Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 06441
End -------------------------------------------------------
Thanks! Tom
Coding: 0021505
Shop #: WSC 00001
1 Fault Found:
Coding: 00044
Shop #: WSC 06441
Coding: 05412
Shop #: WSC 00476
1 Fault Found:
Coding: 00006
Shop #: WSC 06441
1 Fault Found:
Coding: 04097
Shop #: WSC 06441
