Hello Guys!
I was wondering if anyone could help, I still have the OEM boost pipes on my Cupra tdi and I am looking to change at least the top pipe to a hard silicone pipe as I can see it expand when revved even when not under load! Also the connection to the EGR assembly is not tight at all.
Most of the replacement kits I can find seem to only be compatible with a EGR delete kit, as the top pipe doesn't have the little nodules which clip into the EGR and are held in pace with a ring clip.
Does anyone know a manufacturer who supplies hard pipe replacements to the same specification as original or do I have to replace the EGR to buy a hard pipe kit.
Also if anyone knows the technical name or part code of this particular pipe that would also be greatly appreciated.
Thank you
Jason.
Thank you
Jason.
